Trailer ibutton system
Topic: Trailer ibutton system
Hello Guys,
As we need to know how can we install a ibutton system to Truck using  Ruptela Eco4+ Device, Any installation guide where should we install an ibutton to Bind & Unbind the trailer from the truck.
Any idea for Binding & Unbinding the trailer using ibutton system please suggest us, Thanks
Re: Trailer ibutton system
Hi Ahmed,
In Wialon the most common parameter for iButton is avl_driver, and Ruptela Eco4+ also have this one:
http://gurtam.com/en/gps-hardware/auto/ … parameters
After installation and tracker configuring, you can create a sensor for your unit with type "Trailer binding" and parameter avl_driver. Further you should create an automatic binding list of trailers that may be assigned to specific unit.
Related instructions may be found in docs:
http://docs.s-watcher.com/en/hosting/user/ … ic_binding
http://docs.s-watcher.com/en/hosting/cms/u … sors/param
Hi,
Thanks for the information but i need to know how could we install the hardware and ibutton in the Truck with the trailer using ibutton system?
Ahmed try post asking for installing in related topic, this may help find installers in your region.
http://forum.gurtam.com/viewforum.php?id=65
Also hardware manufacturers should provide such services.
