Topic: Integration of GALILEOSKY tracking devices and Technoton sensors
Technoton has completed integration of DFM fuel flow meters, DUT-E fuel level sensors and MasterCAN vehicle data interface with GALILEOSKY tracking device. CAN communication interface has been used (J1939/S6 protocol).
The following devices can be connected to GALILEOSKY (v2.3 Lite, v2.3, v5.0) simultaneously:
DFM fuel flow meters – up to 4 pcs
DUT-E fuel level sensors – up to 8 pcs
Single CAN port of the tracking device is used for connection. All the other analog, frequency and digital inputs of the tracker can be
used for connection of vehicle built-in sensors or non-CAN S6 interfaced sensors (for example axle load sensors).
It is important to note that integration works for out of the box sensors and trackers of mass production without any firmware upgrade.
S6 telematics bus made this possible.
This solution ensures integrators to enter a high-margin market of technological vehicles monitoring for oil and gas and mining
industries, river vessels, complicated multi-engine fixed installations.
Configuration profiles for GALILEOSKY tracking devices and Technoton sensors as well technical support is available at:
Tel.: + 375 29 159-60-61
E-mail: support@technoton.by
Skype: technoton.support
Technical support is free of charge for official partners.
