Navigation
Тема: Navigation
I have run into several situations where users needed to drive to a units location, it would be great if the address/location was clickable and would open in the devices built-in mapping application (Google Maps/Apple Maps).
This would give us the ability to get driving directions and navigation to the unit.
I have added this to custom apps I have made and it should be trivial to add.
Navigation
Re: Navigation
yeah, i also would like to have that!
Wolf.
Navigation
Re: Navigation
Yes, that would be great to have this capability indeed.
Onwards and Upwards!!
Navigation
Re: Navigation
This enhancement is something must have in the application. +100 for this feature.
Navigation
Re: Navigation
cant we do this in GPS Tag it allows sending a destination and the receiver can click Show On Map and then calculate the route between the current location and the received destination.
Phoenix Solusi
Mobile Visible Secure
Navigation
Re: Navigation
Wialon team and Product Managers, Are you listening us? Can't you have this feature in the Wialon App?
Navigation
Re: Navigation
This feature would be very handy.
I have found that some of my clients would like a way to find their assets through a type of google maps idea where the Device of the user is the starting point and the asset is the final destination, and the app on the device would navigate the user to the assets through a maps navigation system.
If for instance the vehicle has broken down or needs maintenance done to it, a simple way to use your app to find the asset through a "take me there" type of system would be great or another example if the asset has been stolen and is on the move the app could be given to response team on the ground to recover the asset.
You can slot this feature next to the command icon when you swipe left on the unit on the app.
I am sure this could be a value added feature that all Wialon users and end users would love to have, especially search and recovery teams who need to find the asset and cant always communicate with the call center who are giving them Directions to the asset.
Regards
Ryan
Navigation
Re: Navigation
Ryan.Gerber,
you can use a long tap on any point on the map to build a route to this point in third-party navigation applications.
https://docs.s-watcher.com/en/hosting/mobi … ng_a_route
Mobile Development
