Signal suppression / sleep mode activation
Topic: Signal suppression / sleep mode activation
Hi,
Can somebody help in with commands to minimize the tracks when the vehicle is switched off . DATA package is finishing too fast.
Using Coban GPS 103.
Attaching the track screen shot too.
Regards,
Abraham
  • Signal suppression / sleep mode activation
Re: Signal suppression / sleep mode activation
enable the sleep mode function. If the HW is ok, it uses a movement G Sensor, if its shitty it uses just ignition line or so (than you cant use it for anti-theft)
Wolf.
also check if there is a static jump filter setting on the device. Jumps will occur just because of usable satellite changes and if a in a built up area this could lead to signal ghosting.
John
Phoenix Solusi
Mobile Visible Secure
