SOS Notifications outside of Geofences
Topic: SOS Notifications outside of Geofences
We are using Queclink GL300VC units and curious to know if a notification will be prompted when an SOS alert is pressed outside of a geofence. SOS alerts are registered during a button press and these button presses are used to indicate if a delivery is made. The purpose of the notification is to determine if a delivery has been made outside of a geofence (delivery area).
Thank you!
Re: SOS Notifications outside of Geofences
it's possible to define sensor value  in notification Geofence , please look here http://docs.s-watcher.com/en/hosting/user/notify/trigger
you can define a required value for sensor which controlled alarm state
the sensor should be created for unit with parameter which device send about alarm state, you can check it in messages
If you doubt about required parameter please write to support@gurtam.com we will specify it in order to device protocol
