locator upgrade options
Topic: locator upgrade options
Hi, we have some request about Locator app, is a very nice app, but we need have an option:
When the unit(s) arrive in to or out from a geofence, the access this unit on locator will be revoked.
Is a kind of action from a notification, like that.
Thanks and regards.-
Re: locator upgrade options
Actually you can do it with the help of notifications.
First, you create a special user. This user will serve only to create locators.
Second, you give this user access to all necessary units.
Third, you create notifications about denying access when certain unit arrives to/lefts certain geofence.
Forth, you configure locator links.
When such notification triggers, the access will be revoken from this user and locator link will lose this access as well.
Katerina Alexandrova
Product Manager (Mobile)
Thanks, i'll try
i want to know if the developers will integrate this options, will be awesome and very helpful.
kellneraressun, I don't think they will, actually.
Because your task can be fulfilled without additional fixes.
Don't you think?
alek, that's right, but the idea is to get better options and more simple.
I made the same thing but without "user locator", i tell you
give the access in locator link through group units (group locator), then i created a notification geofences in/out where the action is modificate the group locator, then the unit what activated the notification will be taken the Group Locator, taken too the access in the locator link.
Thanks.
