Topic: Xeelectech XE209C
Hello everyone !
All our products LK206 LK109 LK106 LK209BC XE108 XE101 XE102 XE103 LK208 LK210 XE201 XE209B/C ... can be supported by Port Xeelectech XE209 .
Hello everyone !
Alarm setting !!!
The parameter "vehicle_status" FFFFFBFF is the bitwise parameter. The value of each alarm can be accessed by using bitwise controls. Here is the link to the documentation for bitwise control http://docs.s-watcher.com/en/hosting/cms/u … sors/param
so you need the drop Alarm function , please creat the Drop alarm sensor with parameter tr_status:2
the SOS = drop Alam !!
tr_status:20 power on/off
Good day ... I wonder what the parameter to be inserted to block fuel via TCP GPRS? What command please?
techtrackrastreamento It depends on the equipment connection scheme (there many ways to block the engine)
Also pay attetion, athat bloking the engine by remote command can be dangerous.
what parameters do i set on the LK206 on wialon platform for panic sos & iginition alerts
evanirungu Ignition is tr_status:11 or tr_status:14
Panic button -- messages should be red by default.
If you have more questions -- pleas ask hw@gurtam.com
Thanks i have been able to set for the ignition but panic still has an issue
As you can see the answer of manufecturer:
I dont know why the LK206 parameters for panic are tricky to set
