Wired door sensor
Topic: Wired door sensor
Hi ,
Can you help me to find a supplier for Magnetic-door sensor ( wired) with Negative trigger ?
thanks.
Sint
Wired door sensor
Re: Wired door sensor
Hi,
www.conrad.com
Here they have many door switches
regards
Baltika
Wired door sensor
also try Aliexpress as they may be a better option than a provider that is based in Europe take a look at
http://www.aliexpress.com/wholesale?cat … tic+switch
Phoenix Solusi
Mobile Visible Secure
Wired door sensor
http://www.aliexpress.com/item/1-set-Wi … eb201560_9
www.guardmagic.com ;
www.tankercontrol.com;
