Topic: Atrack AK1
The issue has been solved, it was the TCP/UDP topic ..... so Wialon accepts only TCP....
Hi Gents,
I am facing the following problem;
A client of us asked us to configure his units on Wialon and not on our own portal. I am experienced in configuring the Atrack series and never faced any issues.
However with Wialon the standard configuration isn't working. The Ak1 is on my desk while the GPS-Antenna is outdoor and has a direct sight to the sky. The ignition on/off is being simulated on a regular basis. The unit is configured on the portal as Atrack AK1-Lite with the port 20646 and the test portal ip 193.193.165.167.
$TRAC=143,15,100,15,0,0,10,0,500,0
$GPRS=1,"public4.m2minternet.com","","","193.193.165.167",20646,1,6,30,0,1,"0.0.0.0",54088
The tracker is sending the tracking data to the server but it is not being displayed on the portal and it is never being seen on http://id.wialon.net/
Any ideas what the problem might be?
Many thanks,
Johann
