chdi wrote:trakfamily wrote:Answer: I am the creator of the user whose token I want to create. I am using the sid of the creator while calling token/update API above. Can you please suggest do I still need to set access_type = -1 and where I need to to set access_type = -1
If you authorized under user-creator through token , sure you should use the parameter access_type = -1 to get token
For example, http://hosting.s-watcher.com/login.html?cl … ion=604800
You can find the full parameters for Extend form here http://sdk.s-watcher.com/wiki/en/sidebar/r … ogin/login
Question: Also you should have access right Operate as (0x200000) to this user to create/update/delete tokens of this user.
Answer: I am the creator of the of the user, when I login into cmd.s-watcher.com and hosting.s-watcher.com using my login/password, I am able to do "Login as another user" the user so I presume I have all the right.
Awaiting your response, and please excuse if my questions are too basic but I am struggling to create token for my sub-user using API. Please help how can I debug the issue.
Please also check is it a correct id of elements you set for "userID" and 'items"
Here are the steps that I performed-
1. To get the token for creator account, I used oauth URL- http://hosting.s-watcher.com/login.html?cl … ion=604800 and got the access_token for creator account.
2. Logged in with creator account using token/login remote API http://hst-api.s-watcher.com/wialon/ajax.html?svc=token/login¶ms={"token":xxxx}, got session id ("eid":xxx) in response.
3. Now to create token for subuser (i.e. of whom on I creator) I called following API-
http://hst-api.s-watcher.com/wialon/ajax.html?svc=token/update¶ms={"callMode":"create","userId":"12822687","app":"","at":0,"dur":604800,"fl":100,"p":"{}","items":["12822687"]}&sid=c066e3e906ffb24fda4ee72716f5eb5a
Where userId and items are the user id of subuser for whom I want to generate token, and sid is the session id (i.e. eid field in step2). But I am still getting Error 7 in response.
Question-1 What does "items" filed in token/update API mean, wialon documentation says "list of item ids with token granted access"? What should I pass to create token for subuser?
Question-2 Can you please suggest what am I doing wrong in above steps? Unfortunately there is no example for http://sdk.s-watcher.com/wiki/en/sidebar/r … ken/update API in wialon playground.
Questions-3 Has anyone used token/update API at all and found it working?
