Start-up GPS business
Тема: Start-up GPS business
Hello guys,
I have a start-up business and needs to know which hardware is reliable with good quality for tracking and monitoring, with added functionality for fuel management, driver behavior, alerts for unauthorized use etc.
I rely on your experience and advise since I know you guys have been in the business and you know what works well  for you.
Ray
Re: Start-up GPS business
Look www.bce.lt
Eduard Vald / GoGPS Service
www.gogps.eu
eduard.vald@gogps.eu
= guardmagic.com
http://guardmagic.com/01-engl/monitoring_on-line.htm
http://guardmagic.com/01-engl/11e-solut … cation.htm
http://guardmagic.com/01-engl/2e-produc … -vb-00.htm
http://www.tankercontrol.com/
www.guardmagic.com ;
www.tankercontrol.com;
(18/06/2015 07:51:05 отредактировано Zprime)
rayykeneg пишет:
Hello guys,
I have a start-up business and needs to know...
Actually, it will be a good idea to tell, at least, your country. Not all manufacturers can trade all over the world, as i know.
And shurely some of non-international manufacturers can produce high quality hardware with outstanding prices, but they can't trade with European or USA markets (for examle), but can work with all other world.
check is out
http://www.calamp.com/products
and for FUEL solution i think the best seller is
http://omnicomm-online.com/
both work toghether so you no need any Enigeering integration
good luck !
Spread the AVL- World
Hi, maybe I can give me my opinion, do you know Jimilab.com, it is a professional website for GPS tracker, car monitor and home monitor and so on, Except this, here are many solutions for solving the problem when you use these devices.
You should do some more analyses!
First: what is your budget for the HW?
Second: do you want to source in asia, in the US or in europe?
Third: do you need some certificates for using it in your country.
After this answer you will get much better answer here.
Wolf.
