Falcom Bolero LT2
Topic: Falcom Bolero LT2
Hi
Can anybody help me with instructions how to put Falcom Bolero LT2 online
I tried by sms commands the device replied ok but its not comming online
if someone has this device firmware update please let me know as falcom has closed support for this product
thanks
Regards
Yoosouf Parvez
From Startouch
Mobile : +23057631200
Falcom Bolero LT2
Re: Falcom Bolero LT2
https://www.falcom.de/fileadmin/downloa … _1.0.0.pdf
and 300 pages of command documentation, enjoy
http://www.rfdesign.co.za/files/5645456 … nd_Set.pdf
I would spent that time on trying to understand how to configure that device only if you need to switch a huge amount of devices.
there seems to be only a "evalkit" which you need to buy to get firmware and config software.
As it is an very old device (2007 or so) and i did not find anything in the public.
I also dont think that typical Wialon User is using this HW!
Wolf.
Falcom Bolero LT2
wwbusch aka Buwo
Thanks for the documentation i have already read and tried the commands as per this documents
i think there is some sort of lock on this device, that is preventing me to script it to send data to wialon
actually i know its an old hardware but i have 2 or 3 customers having more than 40 of these unit on other platform that want to migrate to us.
so its a total around 120 units, that's why  i may need to migrate
i think i need to look for someone that have already this evaluation kit with cables etc...
and also an open firmware
And for this i tried on the internet but in vain till now
I would be glad if this forum may help me out
thanks in advance
Regards
Yoosouf Parvez
From Startouch
Falcom Bolero LT2
(edited by Baltika 23/05/2015 12:18:16)
Hi Guy's,
We sold about 1000 of these units, many are on Wialon ( Hosting & Pro & Local )I think we still have some FirmWare to ""renew"" the inside smile . Some of these units have special customer made software inside ...
regards
Baltika
PS: The file extension is piz  rename this in zip smile
Manuals we can also send ...
Falcom Bolero LT2
(edited by milleniumpower 23/05/2015 22:17:05)
Baltika    we are grateful to you.  Thank you very for the firmware
But i will need the cables as well.  Do you have a link where i can buy it or any evaluation kit ?
thanks again
Regards
Yoosouf Parvez
From Startouch
Falcom Bolero LT2
Hi Yoosouf,
About the cable, it is easy to make yourselves:
1: Take a serial cable with DB9 connector, used on a pc
2: Cut off the right plug
3: Connect the 3 wires like the diagram in the manual to the Bolero connector  Rx>Tx and Tx>Rx   gnd>gnd
Goodluck
Baltika
Falcom Bolero LT2
Baltika   Thanks i will try it and update you on Monday afternoon hope everything goes well
Regards
Yoosouf Parvez
From Startouch
Falcom Bolero LT2
Ahh Baltika, you are always a source of knowledge :-)))
Falcom Bolero LT2
Do you have firmware for Bolero-LT (NOT 2) by any chance?
Thank you.
Falcom Bolero LT2
Did you finally get the units reporting?
Phoenix Solusi
Mobile Visible Secure
