Topic: Internet Explorer - script5 : Access Denied
Hi,
I have develop an application for internal use for the company I work for.
This web app gets the GPS location of my units and puts them on google maps.
I use the Javascript API for the code.
When I open this web app with Internet Explorer 11 some units won’t show anything on the map, even if there are GPS coordinates.
When I open the Developer Tools for debugging, I get the message SCRIPT5:Access Denied which points to the address : https://hst-api.s-watcher.com/wialon/post.html
That messages appears at page load.
At page load I do a login connection to Wialon.
function wialon_login(){
wialon.core.Session.getInstance().initSession("https://hst-api.s-watcher.com"); // init session
wialon.core.Session.getInstance().login("username", "pass", "", // try to login
// if error code - print error message
if (code){ console.log(wialon.core.Errors.getErrorText(code)); return; }
console.log("Logged successfully");
Can someone point me to a solution why I can’t get it to work with internet Explorer 11.
Everything work fine with Firefox & Google Chrome.
Thanks!
