Wialon Playground
Topic: Wialon Playground
We updated our Wialon Playground to make it even more usefull
Here is some of its features
  • number of working demos
  • fork any existing demo to play with it in way you like
  • create your custom demos and share with others
  • save your code as easy as press Ctrl+S
  • get working demo code with 'Get code' button
Try it now, feedbacks are welcome!
Wialon Playground
Re: Wialon Playground
I create an app to track unit and I use wialon javascript sdk (unit trace) when run app in debug mode the map appear but when run app in production mode the map does not appear. I don't know what is the problem.Please help me.
Wialon Playground
Hello heba
Can you expIain what is "production" and "debug" mode in your case?
PS Its better to create topic for such questions
Wialon Playground
is there any documentation on wialon playground  capabilities.Is it possible to run http get request to external server permanently from here
Wialon Playground
siju
There's no any hidden features on Wialon Playground
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script>
All samples have jQuery on it so you can use jquery.ajax to communicate with external server
Wialon Playground
The playground is very helpful for getting to grips with the SDK - thanks for making it available...
Wialon Playground
It's really helpful
Wialon Playground
Keep on scrolling, nothing interesting in this post...
Wialon Playground
Hi!
Whatever example from playground (for e.g. https://sdk.s-watcher.com/playground/demo/app_auth_token) I try I always get the same error - post.html:101 Uncaught DOMException: Failed to execute 'postMessage' on 'Window': Invalid target origin 'null' in a call to 'postMessage'.
    at listener (https://hst-api.s-watcher.com/wialon/post.html:101:16)
How to fix it?
Wialon Playground
Hi gly2008
Try to open sample using http:// protocol via webserver, not file://
Wialon Playground
shmi
I did but <script src="https://hst-api.s-watcher.com/wsdk/script/wialon.js"></script> results the same mistake when executing.
Wialon Playground
Screenshot pls with url you open
Wialon Playground
http://prntscr.com/ondbb8
Wialon Playground
gly2008
Issue not in code. I think its in URL address you open in browser. As I told you cant just double click on index.html file because it will be opened with file:// protocol. You have to use any webserver and open sample like http://localhost:8080/index.html
Wialon Playground
shmi
Thanks!
