little sample code?
Topic: little sample code?
Hi dear guys,
who can help me with a little sample code for the http api:
i need to find out which units are in each geofence.
so i need to have a a little sample code which
- log into the sdk
- scan all geofences
- show units in each geofence
anybody who can help me with that?
thanks
Wolf.
little sample code?
Re: little sample code?
Did you tried http://sdk.s-watcher.com/playground/ ?
little sample code?
Hi Shal,
yes, i tried but the "geofence" test is empty as there are no geofences in the sample accounts and i can not use my own sample account.
as i am not a developer i am not able to setup a webserver and develop this pages by myself.
but i will forward this playground url to our customer and he must try byhimself.
thanks
Wolf
little sample code?
wwbusch aka Buwo wrote:
Hi Shal,
... and i can not use my own sample account.
In every playground sample you can find login code, something like
wialon.core.Session.getInstance().login("%USER%", "%PASSWORD%", "", function (code) { // login callback
  if (code){ msg(wialon.core.Errors.getErrorText(code)); return; } // exit if error code
  msg("Logged successfully"); // print login succeed message
You can change %USER% and %PASSWORD% to your demo account and press 'Test' button in upper right corner to aply changes. See attached image.
About sample code: i'll try to help you in a couple of days, havent time for it now sad
  • little sample code?
little sample code?
Here's sample i promised last week.
Source: https://github.com/ashmigelski/units-inside
Demo: http://ashmigelski.github.io/units-inside
little sample code?
Hi Shmi,
great and big thanks,
that was exactly what i was looking for.
I will forward it to our customer and hopefully he will be happy with Wialon.
Thanks again
Wolf.
