Speed acceleration
(05/02/2014 08:44:23 отредактировано applevamsi123)
Тема: Speed acceleration
I want to know how to create speed acceleration,Speed acceleration-If a vehicle taken speed 10km/h in 1 sec from the 0 speed that can be treated as speed acceleration>can any body know how to do this and this should be displayed in reports.
Опубликовать вложения
Иконка вложений Aug 01 to 22 Aug VehicleExceptionSummary.xls 29.5 Кб, файл был скачан 497 раз(а)
THX
vamsi
Sr.Engg-Technical
Speed acceleration
Re: Speed acceleration
Hi,
create a custom digital sensor with param (speed-#speed)/(time-#time) and set a calc table for it to determine when acceleration is ok or not. Then use this one in reports. And do not forget to convert speed values from km/h to m/s in sensor's calc table.
Developer
