Error: 1 after trying to get notification_data
Topic: Error: 1 after trying to get notification_data
Hi I am getting error: 1 when trying to get notification_data
here is my url
https://hst-api.s-watcher.com/wialon/ajax. … %22col%22:[1]}&sid=ea1e2954971af3daf425394f6ca3f466
I have tried with new session ids, but it is still throwing error: 1 , even with other reques is throwing error 5 or 7, i have never experimented this, the user that i am using is my root user on gurtam sdk, so I would like if there was a change on my permissions or something and if it is, how to reslve.
Cheers!
Thanks for your attention
Re: Error: 1 after trying to get notification_data
Hello
nothing has changed
You login and then can do this request
If you nothing request about 5 minutes  the current session is deleted. After it you will receive a error:1  for any request
Please check more carefully  all parameters.
