New Device CanProbe support CanBus/FMS
Topic: New Device CanProbe support CanBus/FMS
Hello you,
I have the honor to introduce to you a new device running on a server Wialon. CanProbe is a modern and technologically advanced equipment to support FMS CANbus and trowel. Easy to use configuration for the device without the necessary knowledge of the codes. Simply connect the device to the vehicle CAN and select from the list of brand vehicles and control parameters such as fuel control, engine RPM, vehicle mileage and other available for this model vehicle. Knowing that the installer should have knowledge of the device is only CAN wiring in the vehicle.
More knowledge about the device, can be found at: www.canprobe.pl
If you are interested we will send you a current list of vehicles to work with our device.
Please send a request to the following address: flota-gps@flota-gps.pl
If you have questions, we are happy to answer you.
Pozdrawiam / Mit freundlichen Grüßen / Best regards
Wojciech Janowski
CanProbe
Professional solution for telemetry
