Topic: Create command, wialon api
Good afternoon, I can't create a request to get or create a command for one object through Postman. I need to create a command for the object id - 600932328, name - lyuba, command type - custom_msg, channel - virtual, message - setparam:777.
I've already tried a bunch of options for both creating and viewing already created commands, the requests don't work when viewing, I see the object with all the settings (including sensors and arbitrary fields) but there are no commands.
I also tried via https://sdk.s-watcher.com/playground/demo/commands to at least view the commands but it says that the objects are not found although all other requests on the playground work.
Access rights to the object are full, I can see the commands directly in Wialon and I can create them (token from the same account).
