getting error 1 on logout
Topic: getting error 1 on logout
Hi,
sorry for my question, may be it is stupid , I made a lot of search but didn't find anything.
I'm new in the wialon api , working with php files downloaded.
When I'm doing logout
$wialon_api = new Wialon();
$wialon_api->login($cur_token);
[b]some action[/b]
$wialon_api->logout();
[quote]svc=core/logout&params={}[/quote]
I'm getting error  1
Array ( [error] => 1 )  which mean "server connection error "
I need some little help.
Re: getting error 1 on logout
petko.penkov hello, unfortunately, I'm not familiar with PHP, but in Wialon error code 1 means Invalid session. This error may indicate that the session was inactive for more than 5 minutes and it was expired.
Thus, with the execution you get error 1.
Here you may found some codes description -- https://sdk.s-watcher.com/wiki/en/sidebar/ … ors/errors
Anton Zinovyev
Technical Care Engineer (L2)
Hi,
thanks for the answer.
I agree with you, I found that code here https://sdk.s-watcher.com/wiki/en/kit/rem … ore/logout
There is no way to provide sid in the log out , from this URL.
I mean it execute svc=core/logout&params={} and there is no session ID sid.
Regards,
petko.penkov hello, please, accept my apology for the delay. If you execute the request like this:
then you don't need to pass the sid their. But if you execute HTTP request with PHP library then you need to pass SID also. For example: 'https://hst-api.s-watcher.com/wialon/ajax. … mp;sid=SID'
Also, please, make sure that the logout request executes only one time.
Anton Zinovyev
Hi,
thanks for the answer, that fixed my issue.
all is working.
Thanks again.
