Importing Orders - Logistics
Topic: Importing Orders - Logistics
Hi Team,
I am working on the logistics application with bulk import of orders. I am importing orders using an excel file. From the frontend/UI of logistics application, I knew that there is a limit of 19 columns that can be created. I am trying to import orders using the following endpoint: https://sdk.s-watcher.com/wiki/en/sidebar/ … er/update.
I can see the parameters such as n,p,a,e and others which allow to add columns for name, phone, address, email etc. I want to add more than 20 columns using this import option. I found the parameter "cf" where I can add order custom fields. If I pass extra columns I needed as key-value pair using this parameter, will I be able to add more than 19 columns in the frontend. If this is possible and if I pass more than 20 columns, will it get limited in frontend to 19. If this is not possible, how can I add more than 19 columns in the logistics application by having more than 19 columns in the excel file. Could you please help me with this?
Regards,
Jisna
Re: Importing Orders - Logistics
jisnajoby03 hello, there is no specific restriction for the custom fields number. You can create 20 custom fields without issue. The main restrictions that applied in Logistics app described here -- https://wialon-help.link/4897bd58
Also, here you may found details about custom filed -- https://wialon-help.link/027037af and https://wialon-help.link/e0e955c1
Anton Zinovyev
Technical Care Engineer (L2)
