History of Tractor locations (but not trips)
Topic: History of Tractor locations (but not trips)
Hi, when i send this request I can get units' data including gps coordinates
svc=core/search_items&params={"spec":{
                "itemsType":<text>,
                "propName":<text>,
                "propValueMask":<text>,
                "sortType":<text>,
                "propType":<text>,
                "or_logic":<bool>
                 "force":<uint>,
                 "flags":<long>,
                     "from":<uint>,
                 "to":<uint>}
but i want to get history of units by giving the date interval. I could get history data as trips, but  i want to specify the date interval to get history data (but not as trips)
is there any way?
Re: History of Tractor locations (but not trips)
Hello,
1- why do not use retranslator?
2- why do not you create a report based on messages tracing or sensor tracing reports the call the report data by API?
Hi, can you give more detail about what is retranslator? And how we can use it in api call?
Could not find detailed information.
javid.balakishiyev hello, you may found retranslators in Wialon in CMS management. In order to use it, you need to create retranslator, add units in it, set IP and port of the destination server and select communication protocol. Based on the selected protocol you need to proceed the data in the recipient side.
More information about retranslator settings you may found here -- https://wialon-help.link/9d73490c
API requests relate to the retranslators -- https://sdk.s-watcher.com/wiki/en/sidebar/ … translator
Here you may found the protocols integrated in Wialon -- https://s-watcher.com/en/gps-hardware/soft
For more information you may write to support@s-watcher.com with the details about your task.
Anton Zinovyev
Technical Care Engineer (L2)
