Using AVD map in another application
Topic: Using AVD map in another application
Dear GT
I'm developing an application and I want to use AVD map tiles as map in it.
I'm using below code:
<!DOCTYPE html>
<html>
<head>
    <title>Test Offline Map</title>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <link rel="stylesheet" href="https://unpkg.com/leaflet@1.5.1/dist/leaflet.css" />
<style type="text/css">
    html,body {
        overflow-x: hidden; overflow-y: hidden;
        margin:0px; padding:0px;
        font-family: Arial, Helvetica, sans-serif; font-weight: bold;
        color: #666; font-size: 13px;
        height: 100%;
    body {
        background-color: #fff;
        margin: 0; padding: 0;
    img { border: 0; margin: 0; padding: 0; }
    table, tr, td { border: 0; margin: 0; padding: 0; }
    a { color: #333; text-decoration: none; }
    a:hover { color: #000; text-decoration: none; }
</style>
</head>
<body>
    <div id="map" style="width:100%;height:100%;overflow:hidden;background:#000;"></div>
    <script src="https://unpkg.com/leaflet@1.5.1/dist/leaflet.js"></script>
    <script>
    var map = L.map('map').setView([35.70,51.35], 12);
            L.tileLayer('http://{host}/gis_render/{x}_{y}_{z}/{userId}/tile.png', {
                maxZoom: 17,
                zoomReverse: true,
                userId: 55, //id of user 'wialon'
                host: 'WIALON_URL' //here I insert the Wialon monitoring URL and I just removed it not to share it over the Internet
            }).addTo(map);
    </script>
</body>
</html>
But I receive errors like screenshot.
Please let me know what is the problem.
  • Using AVD map in another application
Re: Using AVD map in another application
hhamedk, hello,
Look like that the host value is incorrect. It is not possible to use just monitoring site URL.
Please, use following URL address for host:
render-maps.s-watcher.com/hst-api.s-watcher.com
The example you can find here -- https://sdk.s-watcher.com/playground/demo/gurtam_map
If you face any issues you can also create a ticket to support@gurtam.com and our specialists will handle your request.
Anton Zinovyev
Technical Care Engineer (L2)
zant the server is WL (not WH) so the server URL is fine based on the SDK docs.
hhamedk hello, Thank you for the information. We've received your email and will reply shortly. Please, wait.
Anton Zinovyev
