Logistics API
Topic: Logistics API
Hello I have some questions about your logistics API rest https://apps.s-watcher.com/files/logistics … ces_en.pdf, My question is if I use this logistics service the routes will be created with the same settings used by the user into logistics UI? I mean flags, warehouses, optimizer, etc
How often you update this service?
Regards
Logistics API
Re: Logistics API
cerpas hello, when you create a route with this request, optimization doesn't executes. You can use this service to import order or requesting all available routes. But if optimization is required, please, use standard steps with order/optimize and order/route_update requests. If you mean something else, please, let us know.
Anton Zinovyev
Technical Care Engineer (L2)
