Standard reports and geofences
Тема: Standard reports and geofences
Is there a collection of premade reports that are the most useful, best formatted, rather than starting from zero? I imagine there are some basics that would be a default? The same for Geofences, automatic included geofences for countries, cities, counties, US states, other useful borders? Seems like AI should be able to do this! But until then, is there a collection of these that can be downloaded?
A weather layer would be excellent so we can notify drivers if there is an weather alert. And a dynamic geofence based on weather would be a very interesting feature.
Re: Standard reports and geofences
lionelfelix premade reports did not work well, everybody needs their own settings. Anyway, you can check the premade ones from the attachment (import the files carefully, do not mess up the stuff you already have).
As for the geofences of the states, please send a request to the support@gurtam.com If there are ready to use geofences, they will share them with you.
Concerning weather layer, try adding OpenWeatherMap: https://wialon-help.link/f730e1c9
Опубликовать вложения
Иконка вложений _trial_advanced.wlp 85.29 Кб, файл был скачан 1446 раз(а)
Иконка вложений _trial_agro.wlp 20.21 Кб, файл был скачан 211 раз(а)
Иконка вложений _trial_basic.wlp 13.02 Кб, файл был скачан 214 раз(а)
Иконка вложений _trial_fuel.wlp 29.22 Кб, файл был скачан 1522 раз(а)
Иконка вложений _trial_mgr.wlp 6.72 Кб, файл был скачан 1471 раз(а)
