Retrieving Nearest Geofences
Тема: Retrieving Nearest Geofences
Hello,
Is there a way to retrieve all nearby geofences from specific coordinates, I tried to use resource/get_zones_by_point API but it does not retrieve all Geofences only nearest one
Re: Retrieving Nearest Geofences
mabed пишет:
Hello,
Hello, yes, this request can show only closest geofence, not all geofences inside the indicated area.
Depends on the number of the resources and geofences, you can try to use core/batch request to pass several requests as one with different resources ID for each request, for example:
https://hst-api.s-watcher.com/wialon/ajax.html?svc=core/batch&params={"params":[{"svc":"resource/get_zones_by_point","params":{"spec":{"zoneId":{"RESOURCE_ID_1":[]},"lat":25.753,"lon":80.22222,"radius":100000}}},{"svc":"resource/get_zones_by_point","params":{"spec":{"zoneId":{"RESOURCE_ID_2":[]},"lat":25.753,"lon":80.22222,radius":100000}}},{"svc":"resource/get_zones_by_point","params":{"spec":{"zoneId":{"RESOURCE_ID_3":[]},"lat":25.753,"lon":80.22222,"radius":100000}}}],"flags":0}&sid=
Thus you will get closest geofence from each indicated resource.
Anton Zinovyev
Technical Care Engineer (L2)
