Topic: Converter
Hi there,
How can we tell which measurement system an object is on (user, resource, unit, route)?
Is there an API available for us to check the object and know, Oh! thats Metric, or that's Imperial, etc.
Thank you
Sikandar
Hi there,
Thank you
Sikandar
Hello!
Each element in system like units, users, resources and etc have property 'mu' which means measurement system.
You can get the value of this property from request search_item(s) by adding required flags response
Please look here which flags value for which elements is needed - https://sdk.s-watcher.com/wiki/en/sidebar/ … mat/format
