Update Mileage or sensor on Wialon_api Python
Topic: Update Mileage or sensor on Wialon_api Python
Hi,
I try to use Wialon_api on Python, I don't have any problem for login, to search account informations, unit et sensor informations.
But not possible, to update for example mileage counter. I tried this code, but I j have a WialonError (Access denied unit_update_mileage_counter (7))
I use this code:
        result = wialon_api.unit_update_mileage_counter(itemId=unitId, newValue=newValue)
Do you have a sample to update sensor and mileage ?
Regards
Re: Update Mileage or sensor on Wialon_api Python
Hi!
error 7 means that there is not access right to change mileage value.
Please check if you have the access rights to unit  - https://help.s-watcher.com/help/wialon-hos … s/unit-acl
Also please check the token access rights - https://sdk.s-watcher.com/wiki/en/sidebar/ … ogin/login
the default value is 0x100  only for viewing, so you need to get token with full access right (parameter access_type), for example
https://hosting.s-watcher.com/login.html?access_type=-1
Hi Diana,
Thanks a lot, it's ok, now.
Regards,
Pascal
