I need Help in Customizing Wialon Mobile App.
(edited by ktakyi 27/12/2020 12:57:41)
Topic: I need Help in Customizing Wialon Mobile App.
Hello Team.
I am just starting up GPS tracking business and just entered the tracking theater.
I need help to customize the Wailon app to fit my client's needs.
The Wialon general interface will not be applicable to most of my client's needs. therefore needs some customization.
I will like to have my app interface to look like the following
1:   "home tab" that will show: All, Moving, Stopped, Idle, not connected, offline, expired," units
2:  " Unit Tab":  When highlighted it will bring a new actionable menu that will show the following:
Live Tracking, vehicle info, trip info, engine lock, km summary, engine hrs, report, sensor duration, private mode. fuel level etc.
I have attached a similar interface here for the purpose to achieve the same or something similar.
I will appreciate any assistance and feedback
Regards
Kwame
Re: I need Help in Customizing Wialon Mobile App.
Hello
We're in a similar situation right now.
How has your customization worked out?
Best regards
/bjorn
You may change the visibility of tabs and leave only those tabs that you need. Also you may hide some features or information by denying access to it.
