Regional configuration
Topic: Regional configuration
Hello,
can you send me where do I configure the regional settings?
Consulting sent me this:
You are executing almost the all API requests with the SID. The SID by default heritages the ACL, after set locale request it heritages the locale settings.
And we do not understand them
How do we make the regional configuration before the api call.
any manual?
thanks
Locating things
(edited by hhamedk 28/11/2020 11:35:11)
Re: Regional configuration
locationGPS, We faced same case previously, Pablo.
As I remember you should set locale setting via API after you login (and received SID) or you should set same locale for the top account.
Take a look at below link:
http://sdk.s-watcher.com/wiki/en/local/rem … set_locale
Thanks Hamed, we will take a look on it.
Locating things
I owe you one.
thanks a lot Hamed
Locating things
Don't mention it buddy!
