Topic: Blackberry Tracking Program for Wialon
Question and help to all, anybody is already using or know about a tracking APPS or program that can be use for BB cellular phones if so please can you send me information.
regards
regards
Hello, yes, we have a tracking APP to track Blackberrys, (OS: 4.3+ and Internal GPS) please contact me: soporte@gpsystem.com.mx (Se habla español), Regards/Saludos
isaacpch why isn't your software in the list yet? http://gurtam.com/en/gps_tracking/gps_h … /soft.html
Does it use our Wialon IPS protocol?
I will contact you via email to see how to obtain and test the program
i have tried to contact you by email without respond ,
I sent you the information,
Added after 3 minuts 27 seconds:
hello, What are the steps to integrate?
No yet, we are working about it
just write e-mail to support@gurtam.com and provide following information:
1. Communication protocol (or which protocol was used, e.g. WialonIPS);
2. Exact program name;
3. Manufacturer site;
4. Program screenshot.
Please search in appworld web site , there are FREE programs work with Wialon !!!
Currently one of the most important platforms in business is Blackberry, however, it has been left aside. Wialon has two mobile versions, a very good with google maps and the other very simple and supports only OSM maps. However, the first can only be displayed on Android.
It will be possible to make a special interface for Blackberry? It is a big market.
There is a company from mexico that is working with a retranslation and BB please see the english blog
Thanks, but where can I found that blog?
here is the topic do a search Blackberry Tracking Program fro Wialon
Hola a todos, también estoy buscando alguna aplicación para el Blackberry 9360 compatible con Wailon Hosting, segun Me han indicado utilizar el MGPS tracer version 0.1, pero ese solo opera por Bluetooth externo y no con el GPS interno del dispositivo Blackberry 9360
Alguien sabe o ha probado para integrar el Blackberry 9360 con el GPS interno, con Wialon Hosting
Saludos. . .
No hay nada hecho que realmente funcione bien , el problema es que BB va para abajo, se que no le podemos decir esto a los clientes de LA pero es la verdad no creo que Rim en el mercado coporativo dure 3 anos mas el futuro esta en Android
