How do I know the values of my input parameters?
(edited by fabrizio.pomata 19/06/2020 23:44:34)
Topic: How do I know the values of my input parameters?
Hello. This might sound silly, but I have the following situation:
Our company acquired a fuel monitoring system powered by Wialon.
I am working on a python script to get the data from a report template and load it into the data warehouse (sql server).
I was able to connect with a token and get the eid.
Now I want to execute the svc=report/exec_report command. I tried following this guide: https://sdk.s-watcher.com/wiki/en/pro/remo … es/reports
The problem is I don't know what values to input on params. I mean, ¿Where can I find out the reportTemplateId corresponding to my desired template, for example? I don't know where can I find out any of my param values so I can input them into the command.
Thank you very much.
Re: How do I know the values of my input parameters?
Hi Fabrizio,
First the report, which you would like to execute via API, should be created (in system) in some resource.
Then you can search resource by its name or by report's name to get  resource ID and its reports templates (names and id's)  , using request  core/search_items with the following params, for example searhching by report's name:
  "spec": {
    "itemsType": "avl_resource", //searching item
    "propName": "reporttemplates", //searching report as  subitem
    "propValueMask": "Diana", // report's name
    "sortType": "reporttemplates",  //searching report as  subitem
    "propType": "propitemname" //searching subitem (report)
  "force": 1,
  "flags": 8193, //[url=https://sdk.s-watcher.com/wiki/en/sidebar/remoteapi/apiref/format/resource]flags[/url]: base flag =1 + 8192 report templates
  "from": 0,
  "to": 0
for example JSON response from server
  "searchSpec": {
    "propType": "propitemname",
    "or_logic": "0"
  "dataFlags": 8193,
  "totalItemsCount": 1,
  "indexFrom": 0,
  "indexTo": 0,
  "items": [
      "nm": "dianoch",
      "cls": 3,
      "id": 13,
      "mu": 0,
      "rep": {
        "1": {
          "id": 1,
          "n": "Diana",
          "ct": "avl_unit",
          "c": 53
      "repmax": -1,
      "uacl": 60507498283007
where "items" shows recourse with thier reports : "nm":"dianoch", "id":13 - resource name/id (reportResourceId), "rep"(reports) - "id":1 =reportTemplateId  , report name =  "n": "Diana"
(edited by fabrizio.pomata 22/06/2020 17:42:05)
This was very helpful, thank you very much.
Can I ask you another question? I did the items_search as you said and got the parameters. However, when I execute the report, I still get the 'wrong params' error code.
I believe my reportObjectId is not correct, and I am not sure what to put in there.
My response with item_search was:
{'searchSpec': {'itemsType': 'avl_resource', 'propName': 'reporttemplates', 'propValueMask': 'Cargas', 'sortType': 'reporttemplates', 'propType': 'propitemname', 'or_logic': '0'}, 'dataFlags': 8193, 'totalItemsCount': 1, 'indexFrom': 0, 'indexTo': 0, 'items': [{'nm': 'Reportes_Sentinel1', 'cls': 3, 'id': 187, 'mu': 0, 'rep': {'1': {'id': 1, 'n': 'Cargas', 'ct': 'avl_unit_group', 'c': 59921}, '2': {'id': 2, 'n': 'Consumo Flota', 'ct': 'avl_unit_group', 'c': 60324}, '3': {'id': 3, 'n': 'Control de Peajes', 'ct': 'avl_unit_group', 'c': 31006}, '4': {'id': 4, 'n': 'Descargas de combustible', 'ct': 'avl_unit_group', 'c': 19833}, '5': {'id': 5, 'n': 'Errores de Conducción', 'ct': 'avl_unit_group', 'c': 56306}, '6': {'id': 6, 'n': 'Excesos de Velocidad', 'ct': 'avl_unit', 'c': 2113}, '7': {'id': 7, 'n': 'Extended fuel report', 'ct': 'avl_unit', 'c': 4479}, '8': {'id': 8, 'n': 'Horas Motor', 'ct': 'avl_unit_group', 'c': 26206}, '9': {'id': 9, 'n': 'Infracciones y Multas', 'ct': 'avl_unit_group', 'c': 1276}, '10': {'id': 10, 'n': 'Contador de Viajes', 'ct': 'avl_unit', 'c': 31834}, '11': {'id': 11, 'n': 'Reporte de Paradas', 'ct': 'avl_unit_group', 'c': 7567}}, 'uacl': 17627904754211}]}
Then, in order to execute the report, this is what I do:
http://host/wialon/ajax.html?svc=report/exec_report&
        params={
            "reportResourceId":187,
            "reportTemplateId":1,
            "reportObjectId":59921,
            "reportObjectSecId":0,
            "interval":{
                "from":1590969600,
                "to":1592832842,
                "flags":1
            "tzOffset":-14400,
            "lang":"en"
            }&ssid= my_eid
Thank you very much in advance.
Hi Fabrizio,
there is not parameters "tzOffset"  and 'lang" in method svc=report/exec_report
If you need to get result with specific timezone (not only default UTC+0 time  ), after login you need to execute request render/set_locale
Please note also the parameter  "tzOffset" includes the value of DST settings
For example, for timezone -04:00 without DST  the value is "tzOffset":-134166592
As i wants export report of the unit in pdf format with map location
Step 1
http://gps.tawasolmap.com/wialon/ajax.h … items&
    params={
        "spec":{
            "itemsType":"avl_resource",
            "propName":"reporttemplates",
            "propValueMask":"*",
            "sortType":"reporttemplates"
            "force":1,
              "flags":8193,
              "from":0,
              "to":0
    }&sid=fe63cf3ea518ed7f25826d6e64a41e97
Got result as per that when i execute this command getting "error": 7
http://gps.tawasolmap.com/wialon/ajax.h … eport&
    params={
        "reportResourceId":55874,
        "reportTemplateId":10,
        "reportObjectId":63396,
        "interval":{
            "from":1357938000,
            "to":1358715599,
            "flags":0
    }&sid=379644c21f3a467594d5118d8a9c5e0f
Hello!
it seems like not correct "reportObjectId" or  "reportResourceId", please recheck
Hi thanks for your reply
i got the below response an i have used
reportResourceId: 55874
reportObjectId :63396
  "searchSpec": {
    "propValueMask": "*",
    "propType": "",
    "or_logic": "0"
  "dataFlags": 8193,
  "indexFrom": 0,
  "indexTo": 0,
  "items": [
      "nm": "tawasoldemo",
      "cls": 3,
      "id": 55874,
      "mu": 0,
      "rep": {
        "1": {
          "id": 1,
          "n": "الأحداث",
          "ct": "avl_unit",
          "c": 14647
        "2": {
          "id": 2,
          "n": "الأنتهاكات",
          "ct": "avl_unit",
          "c": 64143
        "3": {
          "id": 3,
          "n": "التسلسل الزمني لحالة المركبة",
          "ct": "avl_unit",
          "c": 63396
      "repmax": 0,
      "uacl": 60610577498111
