Get Token Programmatically
(edited by Jose Donoso 15/06/2020 03:40:08)
Topic: Get Token Programmatically
How to get a token from Windows Services for integration to deploy with external services.
Currently I have to get it by accessing https://hosting.s-watcher.com/login.html
But my Windows services I must implement a function that programmatically get the token.
This is my login function to Wialon:
public Wi_Login LoginWialon ()
   var request = (HttpWebRequest) WebRequest
                             .Create ("https://hst-api.s-watcher.com/wialon/ajax.html?svc=token/login");
   // Here we need to replace the Token variable with a function that allows me to get one automatically
   // var Token = GetWialonToken (); // Get Expected Token
   var Token = "TOKEN";
   var postData = "& params = {\" token \ ": \" + Token + "\"} ";
   var data = Encoding.UTF8.GetBytes (postData);
   request.Method = "POST";
   request.ContentType = "application / x-www-form-urlencoded";
   request.ContentLength = data.Length;
   using (var stream = request.GetRequestStream ())
       stream.Write (data, 0, data.Length);
   var response = (HttpWebResponse) request.GetResponse ();
   var responseString = new StreamReader (response.GetResponseStream ()). ReadToEnd ();
   Wi_Login login = JsonConvert.DeserializeObject (responseString);
   return login;
Saludos,
Sauro Dev
Re: Get Token Programmatically
To get tokens programmatically you can acquire super-token (with -1 acl to the top user) via https://hosting.s-watcher.com/login.html and then create other tokens with token/update by your super-token.
rual, thank you very much for responding. Your advice has been helpful to me.
After making a few changes implement my function GetWialonToken ();
I have passed all the parameters to the function as follows:
https://hst-api.s-watcher.com/wialon/ajax.html?svc=token/update&params={"callMode":"create", "userId":"ESPOLGPS", "h":"4b94588f72a6cbf3769af7987b0e46AF5B14419A1219741453BEEA77E288EA7A4AFD", "app":"test", "at":"0", "dur":"300", "fl":"2", "p":"{}"}
But I get an ERROR.
error 7: reason "OPERATION_NOT_ALLOWED: for 'create' operation you should be authorized"
Do you know the known reason for the error?
Saludos,
Sauro Dev
Currently all API requests require sid parameter with session id. Also, "userId" parameter accepts id, not name.
I wrote full example on js (nodejs) to illustrate which requests you need to do:
const https = require('https');
const TOKEN =
    'XXXX6c5XXXX8272XXXX894a47376c1e8F2XXXX2C4XXXXAF08B231D2D60XXXX2CC4F8XXXX';
const API_URL = 'https://hst-api.s-watcher.com/wialon/ajax.html';
const FOR_USER = 'another';
main().catch((error) => {
    console.error('[main error]', error);
async function main() {
        Login with our super-token to create session for other requests
    let loginResult = await apiRequest({
        svc: 'token/login',
        params: {
            token: TOKEN,
            operateAs: '',
            fl: 0,
    let { eid: sid, au: userName } = loginResult;
    console.log(`Authorized as ${userName}`);
        Search user by name
    let searchItemsResult = await apiRequest({
        sid,
        svc: 'core/search_items',
        params: {
            spec: {
                itemsType: 'user',
                propName: 'sys_name',
                propValueMask: FOR_USER,
                sortType: '',
                propType: '',
                or_logic: false,
            force: 1,
            flags: 1,
            to: 1,
    if (searchItemsResult.items.length !== 1) {
        throw new Error(`Found ${searchItemsResult.items.length} users`);
    let { id: userId, nm: foundUserName } = searchItemsResult.items[0];
        Create token for found user
    let createTokenResult = await apiRequest({
        sid,
        svc: 'token/update',
        params: {
            callMode: 'create',
            userId,
            app: 'Forum example',
            at: 0,
            dur: 300,
            fl: 2,
            p: '{}',
    console.log(
        `Token for user "${foundUserName}" (id${userId}) created: ${createTokenResult.h}`,
        Logout to cleanup session
    await apiRequest({
        sid,
        svc: 'core/logout',
        params: {},
    Function that does API-call
function apiRequest({ svc, params, sid }) {
    return new Promise((resolve, reject) => {
        let req = https.request(
            `${API_URL}?svc=${encodeURIComponent(svc)}`,
                method: 'POST',
                headers: {
                    'content-type': 'application/x-www-form-urlencoded',
            (res) => {
                let buffers = [];
                let totalLength = 0;
                res.on('error', reject);
                res.on('data', (data) => {
                    buffers.push(data);
                    totalLength += data.length;
                res.on('end', () => {
                    let result;
                    try {
                        result = JSON.parse(
                            Buffer.concat(buffers, totalLength),
                    } catch (error) {
                        reject(error);
                        return;
                    if (!result) {
                        reject(new Error('no data'));
                        return;
                    if (result.error) {
                        reject(result);
                        return;
                    resolve(result);
        req.on('error', reject);
        let bodyParams = [];
        if (sid) {
            bodyParams.push(['sid', encodeURIComponent(sid)]);
        bodyParams.push(['params', encodeURIComponent(JSON.stringify(params))]);
        req.end(bodyParams.map((x) => x.join('=')).join('&'));
rual,
Again thank you very much for your time and support.
I have been able to correctly write the user search function by Name, it works perfectly and I get the data.
But, when creating the token for the found user. I get an error.
The parameters I send are:
param=
    callMode:create,
    userId: 1829120,
    app: 'ESPOL', ------>Is this just a descriptive value, or do I have to define it somewhere on the platform?
    at:0,
    dur: 300,
    fl: 2,
    p:{}
And I get the error:
{"error": 7, "reason": "CHECK_TOP_ACL_FAILED"}
Do you have any idea?
Thanks for your help.
Saludos,
Sauro Dev
Looks like original token does not have -1 acl to be able to manage other tokens.
Try to get it with access_type=-1 — https://hosting.s-watcher.com/login.html?access_type=-1
My Friend, if I had you in front, I give you a kiss!!!
Works!!!
I am new to this, I hope to continue learning from You Guru !!!
Thank you!!!. Anything I am at your disposal!
I work in Microsoft Visual Studio technologies, now I implement solutions in Gurtam and GateGps.
Cheers,
Jose Donoso
Saludos,
Sauro Dev
Hi ,
I am trying to create new token with the API call
https://hst-api.s-watcher.com/wialon/ajax.html?svc=token/update&params={"callMode":"create","userId":"xxxxxxx","app":"MIS","at":0,"dur":300,"fl":-1,"p":{}}&sid=
I get response as
    "error": 4,
    "reason": "VALIDATE_PARAMS_ERROR: {app: text, at: uint, dur: uint, fl: int, p: text}"
Asked Gurtam official support they too confirmed my API calls looks correct , can I get some help here?
Sint
HI ,
Found the issue (with help from Gurtam support)
"P" too should be a string "p":"{}"
Sint
