Vehicle Status from GPS
Topic: Vehicle Status from GPS
I have one requirement in which we need list of vehicle status from GPS
Q: - i.e. status came from the GPS system from Event when I create for each vehicle status event manually
How can we achieve above requirement ?
Is there any API to get all status?
Re: Vehicle Status from GPS
Hello!
If user register some statuses for vehicle manually, and then it needs to get registered statutes from some history period, you can load unit messages as event messages just set up "flags":1536,"flagsMask":65280
chdi wrote:
Hello!
No i don't want vehicle status manuaaly
while creating route, i want status of that route
samir.agile wrote:
chdi wrote:
Hello!
Hello!
Unfortunately, it's not so clear what do you mean about route status ? and when creating - build track as message layer, calculate routes in oder to visited points  ? Or you mean somethign which used in Logistics app (https://apps.s-watcher.com/?lang=en#logistics)
Please specify more about it
