Default icon when creating unit
Topic: Default icon when creating unit
silly request....but who knows.
I am tired of the red car icon default.
can be set diferent one from the begininig ??? not selecting the icon??
thanks
Locating things
Re: Default icon when creating unit
cucu3!
Locating things
Dear Pablo, do you know the feature that when you add a unit with default icon into some group, this unit starts to use the group's icon. So you can try this way to change an icon without working with the library.
About the default icon. It may make you tired for sure, but it satisfies the main criteria: it is contrasted on any map and shows the common monitored unit. We may think about smth fresh, but no confidence, that it will be better.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
Hello,
Answer 1, yes, but like this I must set ALL new devices to a specific group so it is equal to edit and change this.
Answer 2, I propose, you decide.
thanks
Locating things
