Order Tracking Webpage
(edited by jaesen 04/12/2019 05:50:28)
Topic: Order Tracking Webpage
Hi Gurtam Dev Team!
We would like to build a page for order tracking by getting the right Wialon Logistics API.
Tracking the order status that has been input into Wialon Logistics.
Attached "Screenshot 173" shows we are able to search by order name (1911165 47) to get the route and the status (estimated time of arrival) of that particular order in the active section.
Attached "Screenshot 174" shows we are able to search by order name (1911165 37) to get the route and the status (estimated time of arrival) of that particular order in the planning section.
Attached "Screenshot 175" shows we are able to search by order name (1911165 35) to get the route and the status (completed with advance) of that particular order in fulfilled section.
We are aware that those moved to fulfilled will be kept in fulfilled for 24hours before removing from that fulfilled section.
Thus, we are setting up the route auto completion with + time of 48 hours "Screenshot 176" to achieve our business needs that the order can be search after 3 days of completion and also we will schedule the deliver within 3 days upon order.
Looking forward to get your advice on which are the best API for us to achieve the above mentioned and what are the settings/ configuration of the selected API.
Thank you in advance, and cheers!
  • Order Tracking Webpage
