Drones and SENSORS in HECTERRA
Topic: Drones and SENSORS in HECTERRA
Hi Gurtam
As part of learning the Hecterra software, I would like to know:
If you have in the list of equipment compatible with Wialon, drones equipped with special sensors for agriculture  (the use of drones equipped with sensors  for agriculture that flies over farmers' fields to make recommendations to them including advice on nitrogen fertilization for example)
Do you have sensors that provide access to weather and agronomic information on plots or fields (Geofence) in real time? In other words, the sensors on the fields or parcels (Geofence) that will collect and process the data that will be sent to either Wialon or Hecterra. Weather-type sensors, anemometer, tensiometric probes, etc ... in other words sensors that adapt to crops
Today the goal for our team is to master the agriculture chain in all these aspects, with the implementation of BIG DATA, Also has a global information system of Wialon with all these components companies (Fleetrun for parts management, Hecterra for agriculture, Logistcs, etc ...) as the operation of ERP such as SAP
Re: Drones and SENSORS in HECTERRA
trackallsecure
As for hardware, you may find the full list of supported devices here
https://gurtam.com/en/gps-hardware
Hecterra as an application, or rather a web service, is able to find cultivations performed on your fields and calculate their different parameters (like cultivated area, overlaps, omissions, spent fuel, etc.).
Using our Hecterra API, however, you may integrate this data into any kind of other services, including the creation of your own unique service or application.
Katerina Alexandrova
Product Manager (Mobile)
Hello!
As a matter of fact there is a piece of hardware, that may match your requirements.
Fully autonomous professional weather station Sokol-M.
It runs on Wialon IPS protocol, therefore making it fully compatible with Gurtam products.
If you wish, I may send you more info regarding this, or you may check it out by yourself at https://www.fmeter.ru/en/produktsiya/me … a-sokol-m/
A harvesting header and feederhouse for use with a crop harvesting machine has a feederhouse interface at a distal end of the feederhouse and a header frame. The header frame has a top beam, a bottom beam, and first and second vertical main structures connecting the top and bottom beams.
Hello There!
As an issue of simple fact there's a part of hardware, so which may possibly suit your own requirements.
Entirely autonomous expert weather channel Sokol-M.
It works Wialon IPS protocol, so thus rendering it entirely harmonious with Gurtam solutions.
(edited by dronebase123 26/08/2020 12:58:40)
Hello There
As many companies provide Live stream HD videos from drones in real-time; control drones & their payloads remotely, over 4G/5G at ultra low latency. Ideal for commercial drones operators, system integrators and enterprises.
They are:-
https://flytnow.com/
https://www.dronedeploy.com/
https://px4.io/
Many More
