Topic: RFID tags
Dears
from your experience, we need to suggest the best RFID type that I can use to identify the containers and also for trailers. also if there is here any manufacturer makes it. he can contact with me shaaban@afaqy.com
thanks
Dears
thanks
The new version of the UMKa310 tracker supports working with iBeacon tags on 4 channels, can imitate the standard iBeacon tag and be a receiver.
You can group tags for drivers, trailers, and two other groups to avoid unwanted identifications. The more advanced UMKa302 can do the same, as well as it works with CAN and supports up to 8 ble fuel sensors
Both terminals also support mutual identification
https://glonasssoft.ru/en/equipment/umka310
We also have RFID identification system (receivers and tags).
https://glonasssoft.ru/en/equipment/umka200
You could use Teltonika device and Blue PUK id?
https://teltonika-gps.com/product/blue-puck-id/
