Проблемы со скриптом
Тема: Проблемы со скриптом
При создание скрипта возникает ошибка. Вот код:
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8" />
    <title>Wialon Playground - Create driver</title>
    <script  src="https://code.jquery.com/jquery-latest.min.js"></script>
    <script  src="https://hst-api.s-watcher.com/wsdk/script/wialon.js"></script>
</head>
<body>
<style>
.btn {
  cursor:pointer;
div {
    margin-bottom:20px;
#log_cont {
    background-color: #EEEEEE;
    height: 150px;
    overflow-y: scroll;
    font-size:75%;
#log_cont table {
    width:100%;
</style>
<div id="base">
    <div>
        Resource: <select id="resource" name="resource"><option value="">-- select resource --</option></select>
        <table id="driver_data">
            <tbody>
                <tr>
                    <td>Driver name</td>
                    <td><input type="text" name="n" value="Ken Block"></td>
                </tr>
                <tr>
                    <td>Driver description</td>
                    <td><input type="text" name="ds" value="Cool drifter"></td>
                </tr>
                <tr>
                    <td>Driver phone</td>
                    <td><input type="text" name="p" value=""></td>
                </tr>
            </tbody>
        </table>
        <input class="btn" type="submit" id="btn_create_driver" value="Create driver">
    </div>
    Log:
    <div id="log_cont">
        <table>
            <tbody id="log"></tbody>
        </table>
    </div>
</div>
var createDriver = {
    init: function () {
        sess.loadLibrary( "resourceDrivers" );
          // flags to specify what kind of data should be returned
          var flags =  wialon.util.Number.or(wialon.item.Item.dataFlag.base, wialon.item.Resource.dataFlag.drivers); // 64 bit OR
          // Subscribe on resource data
            [{type: "type", data: "avl_resource", flags: flags, mode: 0}], // Items specification
            function (code){ // updateDataFlags callback
                if (code) {
                    createDriver.log("Error: "+wialon.core.Errors.getErrorText(code));
                    return; // exit if error code
                createDriver.res = sess.getItems("avl_resource"); // get loaded 'avl_resource's items
                for (var i = 0; i < createDriver.res.length; i++) {
                    $('#resource').append('<option value="'+ createDriver.res[].getId() +'">'+ createDriver.res[].getName() +'</option>');
        $('#btn_create_driver').click( createDriver.create );
    create: function (event) {
        var res_id = $('#resource').val();
        if ( !res_id ) {
            alert('Select resource where you want to create driver');
            return false;
        var res = wialon.core.Session.getInstance().getItem(res_id); // get resource by id
        if ( !wialon.util.Number.and(res.getUserAccess(), wialon.item.Resource.accessFlag.editDrivers) ) {
            createDriver.log('You don\'t have access to edit drivers in ' + res.getName());
            return;
        var $t,
            driver = {
                "itemId":res_id, // resourceId
                "id":0, // item_id
                "callMode":"create",
                "c":"", // driver code
                "ck":0, // image checksum
                "ds":"", // description
                "n":"", // name
                "p":"", // phone
                "r":1, // image aspect ratio
                "f":0, // flags
                "jp":{} // additional fields
        $('#driver_data input').each(function(){
            $t = $(this);
            driver[ $t.attr('name') ] = $t.val();
        res.createDriver( driver, function(code, data) {
            createDriver.log('Driver ' + ( (data && typeof data.n != 'undefined') ? "'" + data.n + "'" : '') + ' create result:  ' + (code ? 'Error('+code+')' : 'Ok'));
    log: function(msg) {
        var $log = $('#log'),
            $log_cont = $('#log_cont');
        $log.append('<tr><td>' + msg + '</td></tr>');
        $log_cont.animate({
            scrollTop: $log_cont[0].scrollHeight
        }, 300);
// execute when DOM ready
$(document).ready(function () {
    wialon.core.Session.getInstance().initSession("https://hst-api.s-watcher.com"); // init session
    // For more info about how to generate token check
    // http://sdk.s-watcher.com/playground/demo/app_auth_token
    wialon.core.Session.getInstance().loginToken("5dce19710a5e26ab8b7b8986cb3c49e58C291791B7F0A7AEB8AFBFCEED7DC03BC48FF5F8", "", // try to login
        if (code){
            createDriver.log(wialon.core.Errors.getErrorText(code));
        createDriver.init(); // when login suceed then run init() function
</script>
</body>
</html>
Запускаю этот код на своем компе и выдает ошибку:
post.html:101 Uncaught DOMException: Failed to execute 'postMessage' on 'Window': Invalid target origin 'null' in a call to 'postMessage'.
    at listener (https://hst-api.s-watcher.com/wialon/post.html:101:16)
Re: Проблемы со скриптом
Отвечено в этой теме https://forum.gurtam.com/viewtopic.php? … 00#p173000
