Need helps on fuel probe from Vietnam LiGO SP
Topic: Need helps on fuel probe from Vietnam LiGO SP
I am a buyer from Pakistan. I just bought LiGO SP analog 700mm 1-5V from SOJI Electronics in Vietnam. Normally, our old installation doesn't require calibration table but they said we have to do it to make sure high accuracy ( create the linear chart ). Is that true? it is the international mutual standard right? I enclosed images of their software for you guys see it
Thank in advance
  • Need helps on fuel probe from Vietnam LiGO SP
Re: Need helps on fuel probe from Vietnam LiGO SP
Muhammad Analog fuel level sensor in Wialon can work with any tracker with analog input.
Calibration of sensor -- it's your own decision. If you want precision values and your fuel tank has non-simple  shape -- calibration is highly recommended.
If you don't need precision result and the tank of vehicle has te simple form -- you can just create the table basing on linear  dependencies full/empty.
Manual is here https://docs.s-watcher.com/en/hosting/faq/hw/hw1
Viktor Yarovenko
Thank in advance
The SOJI Fuel Level Sensor has option for auto-calibration but we recommend you to calibrate by yourself to make sure highest accuracy. It is especially right in case you cut the probe.
To see other specs of SP-AF Analog fuel level sensor, please visit http://sojifuelsensor.com/portfolio/af- … el-sensor/ for more information or contact me.
Vietnam Leading Capacitive Fuel Level Sensor
(edited by mechatronica 23/12/2019 12:59:36)
I think many unexperienced fuel level sensors users make an error mixing two different processes - calibration of sensor and calibration of tank. And answer from manufacturer in fact not correct.
Calibration of sensor - it is an easy procedure to improve sensor range a bit after cutting. It can be automatic or not. Anyway, it takes about 5 minutes.
And calibration of tank is needed to recalculate level data to volume data. Basically during this process sensor (or wialon) is teached by tank shape. You can never find a sensor with such "autocalibration". if tank shape is strictly rectangular you can skip  it but in most cases you have to make this procedure.
eurosenstelematics.com
(edited by zoraya 16/03/2020 15:13:06)
Thanks for the manual.
porn movies
sesso gratis
gratis porno videoer
besplatni porno
Really thanks for the details. Well appreciated
Carmatec
Hi !
Can you please share the programming of Fuel level sensor using LOGO please...
Complete buyer's Guide about Best Kickboxing Shoes in 2021. Get Complete Detailed Reviews about best Shoes for your kickboxing Training.
