JOBS wizard select unit by Group, device type and so on
Topic: JOBS wizard select unit by Group, device type and so on
Hello,
one of the features available in JOBS is the possibility to send commands to the remote devices.
this feature is usefull if for example is necessary to reconfigure the device in order to apply a new setup.
unfortunately now is not possibile to search and select the device by group, device type, or so. This mean that if I need to apply a new setting to all the specific devices I've to select them one by one...
this "missing" function is also in the NOTIFICATION, ie is not possible to search and apply the notification by group, model type and so on.
does somebody have any idea
regards
Ezio
Re: JOBS wizard select unit by Group, device type and so on
Hello edozio,
It is possible to choose unit groups in jobs and notifications -- please, check it in documentation.
@ Oleg Zharkovsky
Thanks for sharing such informative post TelltheBell
