WE NEED HELP In OnCell G3150 Installation on Wialon Local server
Topic: WE NEED HELP In OnCell G3150 Installation on Wialon Local server
Hi...
I have Wialon Local on A static public IP server,,, and i'm planning to install a modem hardware.
the modem is industrial GSM modem with a wide range of capabilities "MOXA OnCell G3150-HSPA-T"
how to configure this modem to work with wialon local server?
and thank you in advance
Mohammed Abu Ghuffa
Re: WE NEED HELP In OnCell G3150 Installation on Wialon Local server
Hello, Mohammed!
First install modem on server and provide needed settings form device manual - we are not able to provide detailed guide how to do this.
Next check on what port is it(wvdialconf can be helpful) or take this info from modem settings.
minicom utility also may be helpful to check modem workability.
Next add needed information in modem settings on admin site tab "wialon" - https://docs.s-watcher.com/en/local/1904/a … lon/modems
If you will have further questions - please feel free to send them on consulting@gurtam.com we will be glad to help.
Wialon Local Expert
Hi
I am looking for a modem to attach to my Wialon local
Did you ever get this working as I am struggling to find a modem that works for SMS
