Topic: Notification regard geofences
hi there GURTAM Team
we are working with trains and the manager asked me for a notification that will be triggered if there was 2 trains inside the same geofence.
any way to do it?
any way to do it?
Hi,
we are working with trains and the manager asked me for a notification that will be triggered if there was 2 trains inside the same geofence. any way to do it?
There is no standard feature to do it in 1 click, but still you can try to combine several notifications to get needful result. You'll need the following:
Please, try it, test it and notify us via support@gurtam.com if you have any questions left.
i thought about that but i have 112 geofences not just one
so if i want to do it this way i will need more than 200 notification
There are no other standard ways to do it with current functional.
You can create your own functional with a help of API or you can send a new feature request to a special forum branch.
