New notification
Topic: New notification
is there is a possibility to trigger an alarm if the unit wan inside a group for more than 5 min for example
or it it sends more than 50 message to the server in a certain time.
New notification
Re: New notification
Regarding your first question I have doubt that Wialon has such a function. But regarding second one, yes, Wialon has it. Please check below URL for more information:
https://docs.s-watcher.com/en/hosting/user … f_messages
New notification
as described in the link it's for sms messages only not the default messages that is send to the server
New notification
No, there is a possibility to set Data Messages (data which are coming from device, what you exactly mean) as criteria. Please double check the link I provided to you.
