Topic: Login to https://hosting.wialon.us/ using Form Post Event
Hi,
I had problem with getToken which i have overcome.
I try this approach but its not working.
We want to directly login to the wailon project by-passing login.
Can you help me with proper steps to overcome the issue. I tried many steps but all were unsuccessful.
<form method="POST" action="https://hosting.s-watcher.com/oauth.html?success_uri=https://hosting.s-watcher.com/post_token.html" id="auth-form" onsubmit="checkLogin(event)">
<input type="hidden" name="response_type" value="">
<input type="hidden" name="client_id" value="App">
<input type="hidden" name="redirect_uri" value="https://hosting.s-watcher.com/login.html">
<input type="hidden" name="access_type" value="256">
<input type="hidden" name="activation_time" value="0">
<input type="hidden" name="duration" value="604800">
<input type="hidden" name="flags" value="7">
<input type="hidden" name="sign" value="D5HVFFw9LaPn7odCubedZk6iANhjW5OVZGtH5hOjTCg=">
<input type="text" class="" name="login" id="login" placeholder="User" value="bizringer" autocapitalize="off" autocorrect="off" dir="auto">
<input type="password" class="" name="passw" value="CDKHoekFCH" placeholder="Password" autocapitalize="off" autocorrect="off" dir="auto">
<input type="submit" value="Authorize"><div id="error_div" class="err" style="display: none;">Invalid user name or password</div>
</form>
I am getting this error:
Your IP has changed or session has expired. Try again please.
My Goal is to..automatically login to wailon web portal from our website.
Thank You....
