Adding Implements Manually
Topic: Adding Implements Manually
Is the manual adding of implements possible? I have added the operations but when I go to the implements tab it is blank, because I do not have them in Wialon. I in the user guide it says they can be added manually. I need to do this as there are a lot of operations that do not use trailers from Wialon.
Phoenix Solusi
Mobile Visible Secure
Re: Adding Implements Manually
JohnG could you please describe an example when an operation does not use a trailer?
Anyway, it seams that for now you will need to create trailers in Wialon to have implements in Hecterra.
Katerina Alexandrova
Product Manager (Mobile)
