Inquiry about reports
Topic: Inquiry about reports
I would like to ask if you can guide us on how to achieve the following additional things. Please note this is a violation report with the purpose of showing and indicating where/when vehicles made over speed incidents:
We need to show in the report the vehicle group name that the vehicle belongs to as a column in the report
Can we show each vehicle in a separate sheet?
Can we display the time when the over speed ended, now we have start time and duration, but is end time possible?
Can we show on the map (for PDF) each vehicle in a separate map, now the map has all over speeding incidents and is hard to view
The default map used for PDF reports, can we change it to Google Maps?
Re: Inquiry about reports
Dear Amir Ashraf
Could you attach an example how do you expect this information to be in the report?
Yes, this option is available. Please, send the request to support, they will give you more details.
This information is absent in the report as we expect that it is excessive. If you have information about start time and duration, you can draw conclusions. If we add the end time you cannot do any additional or more detailed conclusions then you had before.
For now, we have no such option. How you'd use this offline map in your daily business, in what cases? Please, share some examples.
You cannot change the map now. We had such request earlier and will look for a possible solution.
Tatsiana Shmihelskaya
Business Analyst, Gurtam
