For Create Schedule
Topic: For Create Schedule
Hello Team,
we need to use https://sdk.s-watcher.com/wiki/en/sidebar/ … e_schedule to create schedule.
Can you please explain the request params : (we have also checked : https://sdk.s-watcher.com/wiki/en/sidebar/ … ound_data)
How to get below params ::
"tm":[
              "at":<uint>,
              "ad":<uint>, -> what is deviation arrival time ?
              "dt":<uint>,
              "dd":<uint>
     "sch":{
                   "f1":<uint>,
                        "f2":<uint>,
              "t1":<uint>,
              "t2":<uint>,
              "m":<uint>,
              "y":<uint>,
              "w":<uint>
      "cfg":{
              "name":<text>,
              "units":[<long>],
              "enabled":<byte>,  -> we are using 1 for automatic round
              "autoName":<byte>,
              "validityPeriod":<uint>
please explain in details
For Create Schedule
(edited by Diana 18/03/2019 10:41:08)
Re: For Create Schedule
"tm":[
              "at":<uint>,
              "dt":<uint>,
              "dd":<uint>
Hello
"ad"/"dd" parameters means time of deviation (-/+  time )  for point which specified here in web interface (plus/minus column) For Create Schedule
"cfg":{
              "name":<text>,
              "units":[<long>],
              "autoName":<byte>,
yes, it's correct to use "enabled":1 for automatic round, but don't forget to specify unit's id in "units" and parameter "f" should be only 2 -  'Relative to day' schedule type
"sch":{
                   "f1":<uint>,
                        "f2":<uint>,
              "t1":<uint>,
              "t2":<uint>,
              "m":<uint>,
              "y":<uint>,
              "w":<uint>
About 'sch' parameter please look here topic
