Filtering buses based on from and to stops in nimbus locator
Topic: Filtering buses based on from and to stops in nimbus locator
Hello,
At present lot of buses passes through same stop with different route/destination.It will be great for passenger to filter them based on destination stop.
In locator there should be an option to enter from and to stops and display buses passes through both stops and then track them live
Re: Filtering buses based on from and to stops in nimbus locator
Hi siju,
Thank you for this request, we will consider its implementation in future.
Viktoria Chabai
Product Manager, Wialon
