WebServices or connection to database
Topic: WebServices or connection to database
Hello,
I want to integrate Wialon with our CRM/ERP software based on PHP/AJAX. How can I do that?
If you offer webservices it's not problem, but you don't ;/
Direct connection to database? Do you have description of tables?
Best regards
Michal R
Re: WebServices or connection to database
avernet, we have fullt featured webAPI in plans till end of this year. Now you can use Wialon ActiveX, it can also ne used from PHP afaik.
(edited by avernet 29/06/2011 19:40:36)
Can I use direct connection do DB? Do you have any description of DB?
Regards
avernet, direct db connection n/a
Even if we have Wialon Pro hosted on our server?
avernet, yep.
Do you have any tutorial how to use your Wialon ActiveX in PHP?
Here is the link to library: http://monitoring.tracking.by/webActive.php.zip
It has been developed not by Gurtam Team, so docs or tutorial N/A.
this link is incorrect.
http://download.tracking.by/wialon_acti … latest.zip <--- link to download PHP library
С уважением, Станислав Комар
TrackingSoft team.
That link is also incorrect
Nishad Hussain Kaippally
kaippally
PHP sample is here
Developer
duig wrote:
kaippally
PHP sample is here
An error was encountered
Error: uploads/2ff794903c5908d462ba00c772cb417c.ext - this file does not exist.
Please upload file again
duig wrote:
kaippally
PHP sample is here
Уважаемые партнеры!
Прошу поделиться любым файлом-примером у кого осталось.
С форума не удается скачать, поиски в интернете ни к чему не привели.
Заранее спасибо.
Dear Partners
I ask to share any file-example who left.
On the forum you can not download, search the Internet or to no avail.
Thanks in advance.
Re-attaching the PHP sample files.
Developer
